Forums >> Revit Building >> Technical Support >> Importing
4 Posts No Rating |
How would I import something to RevitCity from Inventor or where ever you create the parts? There is a part I want but it is not created yet so can I create it myself?
If you are a member, you can upload Revit families in the downloads area, if that is what you are asking.
You can also make your own parts, and you can download them from other sources like, google 3d warehouse, and of course downloading here, there are many useful families here.
4 Posts No Rating |
Well I was wondering how to create parts then uploading to RevitCity. What is the process to do that?
If you create something in Inventor, you'll have to convert to a format that Revit will recognize. In Inventor, hit the 'BIM Exchange' button and then hit 'export building components'. This will convert the assembly to an Autodesk Exchange File (.adsk). Once you have this file, you can open it directly in Revit. Then save it as a family and upload to RevitCity. Please don't post any Inventor files directly to this site as no one will be able to open it.
4 Posts No Rating |
Ok thank you very much I have been trying to figure this out for awhile now.
4 Posts No Rating |
Is the BIM Exchange ribbon a add on? Because I can not find it on Inventor.
its under the Environments tab
What Version of Inventor are you using?
REVIT'S POOR GRAPHIC DESPLAY WHEN IMPORTING AUTOCAD FILES |
Sun, Sep 24, 2006 at 10:37:22 PM
.sat importing |
Sat, Mar 29, 2014 at 10:44:50 AM
importing sketch up models |
Thu, Aug 16, 2007 at 3:08:24 PM
Importing an image into 3d view |
Fri, Mar 6, 2009 at 3:44:12 AM
importing Topography |
Mon, Jun 5, 2006 at 8:19:08 AM
Members: | 2114980 | Objects: | 23192 | Forum Posts: | 152319 | Job Listings: | 3 |
