53 Users Online (51 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> 2d detail component in 3d wall-based electrical family
Mon, Sep 26, 2011 at 8:18:06 AM | 2d detail component in 3d wall-based electrical family
JeroentjeM
Hello,I've created some symbols for electrical fixtures, as a 2d detail component.
If I want to place these in my model, it would be great if they are wall-based, so I don't have to rotate every symbol by hand. So I created a wall-based family, with only the 2d detail component in it. This works, but not really great.
The 2D detail component no longer really acts as one. If something is on top of the symbol, you no longer see it. While as 2d annotation, I always want to see it, no matter at what height is is, or if anything is on top of it.
Any solutions to this? Thanks!
Mon, Sep 26, 2011 at 11:03:43 AM | 2d detail component in 3d wall-based electrical family
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
Most of the electrical components already modeled, have a 2D symbol associated with them.
Tue, Sep 27, 2011 at 1:12:55 AM | 2d detail component in 3d wall-based electrical family
JeroentjeM
Hmm yes, I see.
But these are 2d annotation symbols, right? This work, but will not scale along. A 2d detail component will scale, so any chance I can use that for my purpose?
Tue, Sep 27, 2011 at 10:17:33 AM | 2d detail component in 3d wall-based electrical family
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
they will scale to the final view, problem with them is sometimes if you are using a really small scale view, they may be large. This is not ACAD, the text will always scale with the view. These symbols, should work fine on down to 1/8" scale. Sometimes like for a kitchen where there are so many conflicting electrical symbols like under cab lights, and plugs, and switches, I will make a 1/2" scale plan of them. You could go back and create a second set of symbols I suppose that are for smaller scale views, by modifying the existing families.
Edited on: Tue, Sep 27, 2011 at 10:19:02 AM
Vertical line-based detail component?
Tue, Jun 3, 2014 at 2:30:54 PM
Nested Annotation Family in a Detail Component
Fri, Mar 16, 2012 at 8:56:46 AM
Line based Detail Component with clean-up?
Thu, Feb 3, 2011 at 3:07:02 PM
Revit 2023 - Line-based Detail Component with mask
Thu, Nov 9, 2023 at 5:57:05 PM
Detail Component in Profile Family - Doesn't Work = Why?
Tue, Dec 22, 2015 at 1:45:51 PM
Page generation time: 1.8008
