92 Users Online (90 Members):
Forums >> Revit Building >> Technical Support >> Revit Line ends
10 Posts No Rating |
When a line is drawn in Revit, the end of the line is a filleted end...its a half circle. in auto cad it is a square end. is there an option somewhere in revit to change the end type of a line?
![eldados Avatar](user_avatar/6083.jpg)
![4.5 Stars: 8 Votes](/images/stars_4.5.gif) |
not that I'm aware off... but it shouldn't matter, you might see it in thick line mode on your screen and won't see the difference when you print.
well, if your line is really really big....then you will see the difference....i think ![Smile](/images/smiles/smile.gif)
If your line is really big consider a filled region... This way you can use a fine line and a solid fill. But yes there should be an option...
Line ends squared off instead of round |
Tue, Jan 2, 2007 at 10:52:47 AM
Line Based Family Joining at Ends [ 1 2 ] |
Mon, Apr 6, 2015 at 12:47:20 PM
16
DIMENSIONING WALL ENDS |
Wed, May 20, 2015 at 8:49:23 AM
Vertical hatch pattern line alignment on wall ends |
Wed, Mar 14, 2012 at 10:04:07 AM
Hidden line types and export to autocad |
Thu, May 4, 2006 at 10:22:40 AM
Members: | 2017432 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
