50 Users Online (48 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Saving New Textures
Thu, Dec 1, 2005 at 10:08:25 AM | Saving New Textures
FlyinHigh
1 Stars: 1 Votes
I have found a new texture that I want to add to my roof but I have problems saving it. Whenever I try to save it to either the user library or any other library, one of two pop-ups appear. They are either Access Denied (that is for the user library) or This File is Read Only (for the rest of the libraries). Does anyone know how to get around this so that I can save this texture? Feedback is greatly appreciated. Thanks in advance.
Thu, Dec 1, 2005 at 5:22:25 PM | RE: Saving New Textures
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
First off your are referring to material/accurender textures? Personally i think you are better off creating your own library. That way when a new build comes out you won't have to worry about your libraries being overwritten accidentally. But you'll need to edit the mlib files to make them not read only in order to add more materials.
Thu, Dec 1, 2005 at 6:39:33 PM | RE: Saving New Textures
geoffy
if you are on a network you may have to talk to your system adninistator and ask them to either allow that folder to be taken off "Read only" status or give you administrator privlieges. I agree with Mr Spot it would be easier to create a new library under your personal folder (my documents) under the backed up section of your computer that way if some thing happens to your C: drive all your files are safe and out of harms way. Hope this helps
free hi res textures
Mon, Apr 13, 2009 at 2:47:30 AM
Revit render textures - any good resources on the web?
Thu, Dec 16, 2010 at 10:54:16 AM
adding textures to wall
Tue, Oct 17, 2006 at 9:27:47 PM
High Res Textures for Rendering
Fri, Apr 17, 2009 at 12:15:30 PM
ADD TEXTURES AND HATCHS
Wed, May 6, 2009 at 7:59:51 AM
Page generation time: 0.4677
