63 Users Online (61 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Corrugate / Profiled Metal Wall & Roof Cladding
Wed, Sep 21, 2011 at 8:53:35 PM | Corrugate / Profiled Metal Wall & Roof Cladding
sandh01
3.5 Stars: 2 Votes
Hi,
I am trying to make a building that has a corrugated metal wall cladding and roof cladding.  I want it to look more realistic when I render so I am trying to make these profiles as part of the wall / roof itself.  I ave tried to create a new profile of the corrugate metal then apply it as a sweep to the wall properties, but this just crashes Revit everytime so I must be doing something wrong?
The profile is a typical repetitive corrugation style.  The profile I created includes several of these repetitions up to a length / height of about 3m.
Thu, Sep 22, 2011 at 1:24:52 AM | Corrugate / Profiled Metal Wall & Roof Cladding
4thAngel
4thAngel Avatar
Hi,
have you checked here?
http://www.revitcity.com/forums.php?action=viewthread&thread_id=2952
Thu, Sep 22, 2011 at 2:51:13 AM | Corrugate / Profiled Metal Wall & Roof Cladding
mansell5
3.5 Stars: 4 Votes
see this blog about profiles http://revitfamilies.blogspot.com/
cheers from Orstralia
Thu, Sep 22, 2011 at 8:50:32 AM | Corrugate / Profiled Metal Wall & Roof Cladding
I have done several metal building types and I only use material patterns rather than modeling these profiles.  Unless you have a rendered view where the camera is only a few feet away from the surface, the material works just fine.
Think about how we assign just a material for brick or block.  Yes, the "bump" in metal panels is greater than brick but it still works.
If you have a very small building, then you might be able to model this and get away with it, otherwise, good luck!
Thu, Sep 22, 2011 at 2:30:26 PM | Corrugate / Profiled Metal Wall & Roof Cladding
sandh01
3.5 Stars: 2 Votes
Thanks guys, I did search the forums for this topic but didn't find that thread.  I have already created a sweep for the walls which looks fantastic as the troughs of the metal corrugate profile are quite large and as they are horizontal it gives a great true shadow.  It does slow the model down a tad though so I will look into using the materials more, thanks for the feedback!
Thu, Sep 22, 2011 at 3:00:21 PM | Corrugate / Profiled Metal Wall & Roof Cladding
This might help for materials: http://steelselect.com/content/viewresource.php?id=4284search.results.php
Thu, Sep 22, 2011 at 3:56:31 PM | Corrugate / Profiled Metal Wall & Roof Cladding
AbsoluteBIM
AbsoluteBIM Avatar
4 Stars: 4 Votes
We use a corrugated vertical metal siding for most of our buildings. I made this bump pattern for renderings. Using accurate geometry really bogged the file down so this works great!
Cladding
Mon, Jan 23, 2017 at 3:27:54 PM
How to create a new wall/roof type?
Thu, Jun 19, 2008 at 10:15:38 AM
wall cladding
Wed, Dec 10, 2008 at 8:54:00 AM
Need rendering material for metal roof and metal wall panels. Red paint finish.
Thu, Oct 26, 2006 at 5:09:27 PM
Cladding
Wed, Jun 12, 2013 at 3:01:53 AM
Page generation time: 6.2465
