47 Users Online (46 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> Newbies >> Wrap wall finish to window ledge finish
Wed, Sep 21, 2011 at 12:16:58 PM | Wrap wall finish to window ledge finish
ctrlsb4f9
Hi all,
I have a double wall condition where I need to have an outer, lower wall wrap to a horizontal ledge that intersects another, inner wall which is hosting the windows. I need to have the outer wall EIFS finish wrap cleanly to the horizontal ledge EIFS. I have tried doing the horizontal part with Floors, Ceilings, Roofs, etc, without much luck. Anyone know how to do this cleanly and easily?
Thank you for the assistance
Wed, Sep 21, 2011 at 1:22:52 PM | Wrap wall finish to window ledge finish
Add a wall sweep with your wall finish material.
Wed, Sep 21, 2011 at 2:55:12 PM | Wrap wall finish to window ledge finish
ctrlsb4f9
Thanks W,
I have been searching around for a tutorial on how to make a sweep do what I want (to show the horizontal finish material continuous with the vertical wall finish material), but all I have found are lessons on using parapet caps and moulding. Are you familiar with anything that might illustrate how to make this work?
Thanks again
Wed, Sep 21, 2011 at 2:57:37 PM | Wrap wall finish to window ledge finish
You can do it with a regular wall sweep then paint the exposed top face or you can do it with an in-place sweep that has an assigned material.  I would probably do it with the wall sweep.
Wall type wrap
Thu, Nov 26, 2009 at 3:25:41 PM
Wall finish to wrap around on storefront (not to interior)
Mon, Feb 20, 2017 at 1:35:27 PM
Wall wrap problem
Sun, Aug 2, 2015 at 11:54:46 AM
Hiding finish line of wall in plan
Wed, Apr 1, 2015 at 7:04:51 AM
Window cuts different size for core and finish layer? (RAC 2010)
Wed, Oct 14, 2009 at 8:44:55 AM
Page generation time: 1.4578
