64 Users Online (63 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> extracting hatch pattern from autocad file
Wed, Sep 21, 2011 at 10:39:33 AM | extracting hatch pattern from autocad file
dgtmantis
I need to change the scale of a pattern in revit that was imported from a .pat file.  The problem is I have lost the .pat file!
I have exported the revit file to a dwg and have used the lisp routines PATOUT and GETPAT.  I loaded both of them into autocad and selected the hatches and both of them said they were exracted.
The problem is that I can't find them anywhere. I assumed they would be in the C: Documents and Settings: User Name: Application Data: Autodesk: AutoCAD 2011: R18.2: enu: Support...but they are not there.  I even checked the default acad.pat file thinking they may have been added to that file but no.
Anyone used these lisps?  Where are the extracted patterns located?
-dgt
Wed, Sep 21, 2011 at 10:47:58 AM | extracting hatch pattern from autocad file
3.5 Stars: 395 Votes
Did you try changing the scale in cad, then importing that view into a cleanup revit file to get the pattern at the right scale?
Wed, Sep 21, 2011 at 10:57:14 AM | extracting hatch pattern from autocad file
dgtmantis
Yup...tried that before I decided to attempt to extract the hatch.  AutoCAD shows the hatch but since there is no definition in .pat format, it cannot change the scale.
Wed, Sep 21, 2011 at 2:23:59 PM | extracting hatch pattern from autocad file
dgtmantis
OK...Well, I found a workaround.  I downloaded "HatchMaker" and recreated the hatch I had in the autoCAD file.  Not nearly as good as the original hatch that I had lost the .pst file for but I have to take what I can get!
Just in case anyone else has this problem, here is the link to hatchmaker:
http://cadtips.cadalyst.com/patterns/hatch-maker
Thanks!
Wed, Sep 21, 2011 at 4:01:20 PM | extracting hatch pattern from autocad file
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
You can also get the free "hatch22" plugin for revit, which allows you to draw any hatch pattern you desire.  Model hatches, to scale.  I find it incredibly useful, particularly for wood grain, which has always looked exceptionally hokey in all .pat libraries in the history of CAD.
I reccomend keeping a separate project on your network titled 'hatch library/playground" or such.  Draw and test your hatches in there, and then copy/paste a filled region into your actual project.
Edited on: Wed, Sep 21, 2011 at 4:02:02 PM
autocad hatch problems
Thu, Dec 14, 2006 at 2:19:07 PM
Export to Autocad 2005 (Hatch Patterns Go Missing)
Mon, Feb 14, 2005 at 6:13:58 AM
Exporting hatch pattern
Thu, Sep 18, 2014 at 6:27:35 PM
Stray Lines in custom Revit fill pattern
Mon, Jul 8, 2013 at 8:02:44 AM
New pat pattern help
Tue, Nov 1, 2011 at 8:26:43 AM
Page generation time: 1.2660
