74 Users Online (72 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Changing the amount of contours between intervals.
Tue, Sep 20, 2011 at 2:27:26 PM | Changing the amount of contours between intervals.
Cbart78
I have a topographical map that I am trying to make that has intervals set at 10'
by me. The program auto matically makes coutour lines between the 10' intervals
every 1'. Is there a way for me to make it so that the contours that automatically
appear show up every 5' instead of 1'?
Thanks!
Chris
Tue, Sep 20, 2011 at 2:29:57 PM | Changing the amount of contours between intervals.
Cbart78
I am using Revit 2011.
Thanks!
Chris
Tue, Sep 20, 2011 at 2:38:12 PM | Changing the amount of contours between intervals.
Massing & Site tab / model site pull down / set your intervals as well as primary / secondary contour settings.
Tue, Sep 20, 2011 at 3:00:40 PM | Changing the amount of contours between intervals.
Cbart78
Thank you very much.
Chris
Showing contour lines at different intervals?
Wed, Apr 9, 2008 at 6:07:39 AM
Contour line intervals at different scales
Thu, May 3, 2007 at 11:16:59 AM
Revit toposurface detail level
Fri, Feb 11, 2011 at 1:45:01 PM
Changing existing and new contour lines
Tue, Jul 17, 2012 at 9:08:56 AM
Smoothing contours...
Tue, Feb 17, 2009 at 8:43:14 AM
Page generation time: 0.5788
