145 Users Online (143 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Lines made with linework tool disappear
Tue, Sep 20, 2011 at 10:04:59 AM | Lines made with linework tool disappear
Schiette
I've made a custom 'structural framing' element. The family settings are set to 'Symbolic Representations: from project settings'.
In my project, I change the cutting plane of my view range higher. After this, I change some lines to 'overhead'. When I change the view range back to the normal height the lines disappear. The top view range is set to 'unlimited'.
I'm really desperate on this one. I've been looking for a solution all afternoon, and we're loosing valuable time...
Tue, Sep 20, 2011 at 10:14:10 AM | Lines made with linework tool disappear
Schiette
I forgot to mention: I work with Revit 2012
Tue, Sep 20, 2011 at 10:18:53 AM | Lines made with linework tool disappear
Schiette
Oh, and the problem only occurs when the family is cut. When I test this on objects that aren't cut, the lines don't disappear.
Tue, Sep 20, 2011 at 11:30:07 AM | Lines made with linework tool disappear
The only way I have done overhead lines is the process described in the HELP:
"For example, in a Level 1 floor plan view, you can specify Level 2 as an underlay. If Level 2 has a roof, you can select the roof in the plan view and then modify it. You can even underlay the same level as the view to select a ceiling or beams or other elements that are not shown in the view. You can use the Overhead line style for tracing underlays or define your own line style."
That method works, your metod does not.
Tue, Sep 20, 2011 at 12:14:02 PM | Lines made with linework tool disappear
Schiette
Thanks for your reply,I really appreciate it. The problem is that my family is cut by the cutplane, and the parts that i want to use the lineworktool on are above the cutplane (so it's invisible!). No matter which underlayer i use, it remains cut! So i really see no other method than to temporary raise the cut level and lower it after using the lineworkstool. Hope you can help me out!
Wed, Sep 21, 2011 at 1:02:53 AM | Lines made with linework tool disappear
Schiette
Please forgive me my patience, but is there somebody who can help me? We're currently putting a stadion in Revit and this problem threatens our deadline.
Wed, Sep 21, 2011 at 7:12:28 AM | Lines made with linework tool disappear
Don't use the linework tool, use 2D linework.
Wed, Sep 21, 2011 at 7:46:23 AM | Lines made with linework tool disappear
Schiette
Thank you very much! This does work :-)!
Linework Tool
Mon, Jul 28, 2014 at 8:42:22 AM
Linework tool issue
Mon, Sep 26, 2011 at 3:20:44 PM
Linework Tool Issue
Thu, Nov 20, 2014 at 7:18:16 AM
linework tool - original showing up next time I open revit project
Fri, Aug 8, 2014 at 2:18:21 PM
Linework Tool (LW)
Thu, Mar 11, 2010 at 4:34:30 PM
Page generation time: 1.4382
