33 Users Online (30 Members):
Forums >> Community >> Newbies >> doors
2 Posts No Rating |
how do you place door on the correct elevation when creating a split level home
just go to an elevation view and put the door anywhere you want it.. is that what you want to know?
For split level buildings, you really need both levels as levels. Then simply host your door on the correct level. You should do the same with your rooms - walls - windows. Anything that is level related or reports its location by level.
Although you may show both levels in one plan, I suggest you have a working plan for each level. Then when you place objects, simply work in the correct level plan view.
Anyone have pocket doors or pivot doors? |
Tue, Jun 25, 2019 at 12:37:56 PM
dOORS AND DOOR SCHEDULES |
Mon, Aug 6, 2007 at 11:28:15 AM
Curtain wall doors wont center up |
Mon, Oct 12, 2009 at 4:28:48 PM
doors opened in 3D views |
Wed, Sep 27, 2006 at 9:20:29 AM
Doors not appearing in door schedule... Help |
Thu, May 30, 2013 at 11:58:43 PM
Members: | 2026013 | Objects: | 22991 | Forum Posts: | 152208 | Job Listings: | 3 |
