40 Users Online (39 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Cut plane hatch missing from one type of wall
Mon, Sep 19, 2011 at 4:17:18 PM | Cut plane hatch missing from one type of wall
SpanMan
Revit City,
All of my walls are showing the correct cut plane hatch except on my generic wall. My view range is set to see -1"  and i know the wall goes up to 0. type of hatch doesnt matter just want to see it. I am in a structural plan view drawing a framing plan.
Any thoughts?
(Revit 2012)
Mon, Sep 19, 2011 at 4:22:26 PM | Cut plane hatch missing from one type of wall
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
I assume you are speaking of the provided generic wall. Several things affect the detail of the walls in view, detail levels set to coarse will likely not show a hatch. If the wall itself does not have a hatch assigned to it. Please post a view, and a view of the properties box, with a view of the particular section properties. You may want to download Jing, it is free and is very helpful for capturing pictures of your screen, and sharing with others on the chat or in the forums.
Edited on: Mon, Sep 19, 2011 at 4:24:33 PM
Mon, Sep 19, 2011 at 4:32:03 PM | Cut plane hatch missing from one type of wall
SpanMan
-Detail Level is set to Fine.
-When i edit type i change the material to Masonry and the hatch to diagonal crosshatch.
Mon, Sep 19, 2011 at 4:33:00 PM | Cut plane hatch missing from one type of wall
SpanMan
The wall not showing the watch is next to the wall with the diagonal hatch
Mon, Sep 19, 2011 at 4:34:14 PM | Cut plane hatch missing from one type of wall
SpanMan
I will download Jing tmrw. thankyou for the quick post
Tue, Sep 20, 2011 at 9:54:21 AM | Cut plane hatch missing from one type of wall
Your image makes no sense with your question.
I can't tell if this is the issue but Revit has always had trouble with very short walls.
Cut Plane display issue
Tue, Oct 11, 2011 at 12:48:43 PM
Getting Cut Wall Hatch to move WITH the Wall
Fri, Aug 10, 2012 at 2:59:51 PM
Cant see wall material cut in plane
Mon, Sep 29, 2008 at 3:08:28 PM
14
Wall hatch & Interior lines not showing when cut
Fri, Oct 26, 2007 at 7:24:35 AM
applying multiple hatch to wall
Wed, Jan 2, 2013 at 5:35:11 AM
Page generation time: 1.8636
