49 Users Online (48 Members):
Forums >> Revit Structure >> Technical Support >> Any way to set Wall Join Display to not clean any walls?
When doing a tilt-up building, it would be very nice if the default wall join setting was "do not clean any joins". But I only get two options, "Clean all joins" and "clean same type joins". Is there a trick or workaround to get it to not clean any joins?
Thanks.
Most people do not use wall segments for tilt up walls. Since I don't schedule individual panels, I use a continuous wall with vertical wall sweeps (voids) at the panel joints. When you do need to schedule the panels, some users use curtain wall with the panels being a wall panel and the muillions the joint.
Wall Join Display |
Thu, Oct 14, 2010 at 12:52:50 PM
Clean wall join |
Sat, Apr 20, 2013 at 3:30:48 AM
11
Wall Join clean up |
Wed, Mar 6, 2013 at 12:14:30 PM
90degree wall join |
Sun, Aug 20, 2006 at 9:08:54 PM
wall joins at stacked wall not clean |
Mon, Nov 15, 2010 at 11:57:34 AM
Members: | 2042232 | Objects: | 23026 | Forum Posts: | 152216 | Job Listings: | 3 |
