63 Users Online (61 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Some trees not casting shadows
Sun, Sep 18, 2011 at 1:24:10 PM | Some trees not casting shadows
sattoji
I have a topo surface with RPC trees, and a curious problem... with shadows and sun path turned on, I get shadows cast on 90% of my trees, but some trees near the periphery don't cast any shadows (see screenshot). These trees are exactly the same family type and have all of the same visibility settings w/ no overrides. The ground planes are such that they should receive shadows. It almost seems like a problem of the range of the sun's shadow casting - for some reason it is cutting off the lower right and mid-left portions of the site?
MacBook Pro 2.66 GHz Intel Core i7 running Windows 7 Pro 64-bit on Parallels 6
Wed, Oct 10, 2012 at 4:03:57 AM | Some trees not casting shadows
albionarchitect
Hi. I found that trees with some transparency (revit 2013) do not cast shadows. I am using trees from archigrafix (http://www.archigrafix.com), i am not sure what trees you are using . however I guess the transparency/shadow applies to all objects in revit.
Sat, Mar 9, 2013 at 4:46:52 AM | Some trees not casting shadows
Lucylou
I had this problem in Revit 2013.
My trees were transparent and not casting a shadow (and everything else was) so I edited the tree family.
Drew a selection box over the tree foliage so they're highlighted, opened material editer.
I just duplicated the material and then changed the transparency to 0... saved family and loaded into project.
My trees cast shadows now Smile
Lucy
Thu, Oct 16, 2014 at 10:55:23 AM | Some trees not casting shadows
fourtonil
You can also open the tree family and open its visibility settings and check "Plan/RCP" for the tree to display.  The shadows will show in plan view.
Trees not casting shadows on shadow study??
Sun, Apr 3, 2011 at 12:14:34 AM
11
Revit 2011: Linked model not displaying casting shadows
Tue, Sep 28, 2010 at 1:55:14 PM
shadows
Mon, Apr 18, 2005 at 2:55:12 AM
Help Glazing casting shadows in sun studies
Wed, Dec 16, 2009 at 7:19:41 PM
Casting Shadows on to a JPEG
Wed, Jul 21, 2010 at 4:17:52 PM
Page generation time: 1.3894
