106 Users Online (105 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Link Cad Drawing Problem
Sun, Sep 18, 2011 at 1:12:01 PM | Link Cad Drawing Problem
driftergirl
Hi Everyone,
I am new to Revit and our office is using Revit 2009. One of our projects had been done by someone outside and there are linked drawings in the revit file. I need to edit something on the linked file. After editing and saving the cad drawings I went to the manage link and reload the file pointing to the new folder location but then there's a message saying "Some elements were lost during import. ActiveX and some proprietary components cannot be imported. Try exploding the file in Autocad or setting proxygraphics to 1." I did that but when I try reloading again same message appear and the revit file is not updated. I've been reading forum threads online but I can't find an answer. Attached is a screenshots of the message. I hope you guys could help me. Thanks!
dana
Mon, Sep 19, 2011 at 11:36:34 AM | Link Cad Drawing Problem
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
try exploding everything in the dwg multiple times. sometimes once is not enough
Tue, Sep 20, 2011 at 7:22:00 PM | Link Cad Drawing Problem
driftergirl
I tried it several times and I also made sure that the proxygraphics value is 1 but then when I tried reloading the linked cad drawing on the revit file I still get the same error. Please help!
Thank you,
Dana
Link CAD problems
Fri, Feb 1, 2019 at 6:08:02 AM
Link CAD, Import CAD in the middle of space
Tue, Sep 21, 2010 at 3:43:46 PM
CAD inserts appear in as many copies in my manage link view
Fri, May 15, 2020 at 5:17:44 PM
Importing a cad file
Fri, Apr 27, 2012 at 3:33:21 PM
Insert/Link CAD Advice
Wed, Dec 21, 2011 at 2:56:22 PM
Page generation time: 5.7624
