Forums >> Revit Building >> Technical Support >> Cable Stayed Mast from a curved roof
Hello,
I have this school design of a boatyard curved roof that I´m trying to put into revit but I´m having some troubles. I´m hoping I can get some tips on how to set the stayed cables as it´s shown in the picture added. I tried to use the mass sweep tool but couldn´t set the proper work plane as the surface is curved, so I couldn´t draw the little circle in the right position to run along the line from the roof to the top of the mast. I know there´s got to be something really easy I´m missing. Any ideas?
I would make a parametric family called cable that allows you to adjust it's length. Non-hosted. Create a work plane that biscts your form verticall, place multiple copies of the family on this plane, rotate them and adjust their lengths as appropriate.
Maybe this can help: http://www.youtube.com/watch?v=-ZVxs02TQeY
Or create a "Generic Model Line Based" to create those cables
Edited on: Sun, Sep 18, 2011 at 6:05:49 AM
Thanks a lot for your tips guys!
I´m going to try to make a cable general family. That video is great, but I just didn´t get that the guy did, shame the video is too fast and without audio, but that is certainly a great exercise and I hope one day to get to this level.
Thanks again
thanks mbsteve but I couldn´t open your file, you probably saved as a 2012 version, if you could save as an earlier version I´d even more grateful.
Sorry Maycon,
I have closed out my 2011 version, and just use the newest version, they are not backward compatible.
no worries man, I appreciate your help anyways, Im going to try to make my own, this way I´ll overcome my laziness and take it as an exercise
Good attitude
Modeling a kind of cable stayed structure |
Thu, Nov 12, 2015 at 12:18:26 PM
CURVED MASSING FOR ROOF BY FACE |
Tue, Jul 20, 2010 at 5:24:24 AM
How to do Cable Tray with Real Material Color (Not just filter color) |
Wed, Feb 18, 2015 at 3:14:07 AM
Sloped and curved roof |
Mon, Jan 2, 2012 at 10:07:28 AM
Curved roof with sweep? |
Fri, Jan 9, 2009 at 5:26:10 PM
Members: | 2017920 | Objects: | 22948 | Forum Posts: | 152215 | Job Listings: | 3 |
