Forums >> Revit Building >> Technical Support >> That sketchy look
Sat, Sep 17, 2011 at 1:46:50 AM | That sketchy look
Pele
Pele Avatar
I read an article from Revitup (website/blog) about a way of giving a revit drawing/file that sketchy look. I was able to do it in ACA but it was a bit clumsy, well not clumsy but it took up a lot of computer/space, resources.
Anyhow I read the article & it looked good but it does not seem to work. I am using Revit 2011 & Sketchup version 8.
 The article instructs to save your Revit file to AutoCad 2004, then import it to Sketchup. Then in Sketchup you can do the sketchy look. Apparently the model can be rotated in Sketch up aswell. http://www.revitup.co.za/_mgxroot/page_10866.php
The sketch look is a good tool to use for preliminary concept dwgs to re-enforce to the client that the dwg is only a sketch. I find that if they get dwgs that are a bit formal in 3d or flat they can get the impression that the drawing is further down the track of developmet than is intended.
Does anyone use the sketchup tool or even better is such a thing possible in Revit?? Maybe the versions of Revit & Sketchup have changed & these things are not supported anymore
I will be scoring goals soon, I'm in the back line at the moment!
Cheers Dermot
www.dmbd.net
Sat, Sep 17, 2011 at 9:22:52 AM | That sketchy look
With your Revit subscription, you should have gotten a copy of the program Impressions.  That works very well to do what you want.
Sat, Sep 17, 2011 at 11:36:38 PM | That sketchy look
Pele
Pele Avatar
Used to be on subscription but a bit low on work & let it slide! Yes impressions is a good program for that I forgot, maybe I can pick it up again before next year so it does not cost too much again.
Cheers Dermot
www.dmbd.net
Model gone sketchy in 3d?
Wed, Oct 15, 2008 at 8:48:48 AM
Revit 2014 - We need a sketchy rendering style workflow - Any suggestions???
Thu, Aug 22, 2013 at 7:54:45 AM
sketchy lines lineweight
Mon, Jun 9, 2014 at 2:10:11 PM
How do I make my lines look "sketchy"?
Tue, Feb 5, 2008 at 7:24:46 AM
Sketchy Revit
Wed, Dec 7, 2011 at 11:17:39 AM
Page generation time: 1.2873
