76 Users Online (74 Members):
Forums >> Revit Building >> Technical Support >> Revit 2012 Elevation Display Issue
13 Posts No Rating |
Hi all,
Ive been using revit since 2008 and have never had this issue before. My building elevations are displaying transparent dispite being set to Hidden. Is anyone else having this issue? Know a fix? I have checked all the things I can think of; display setting, depth clip, transparency of walls...etc.
Please help.
do you have any dwgs linked in?
I have had this problem from linking consultant backgrounds into my building. I ended up having to explode the dwgs and make sure they were centered(ish) on 0,0
Edited on: Thu, Sep 15, 2011 at 7:00:32 PM
I've seen this issue. It was related to a corrupt view (usually caused by having lots of items in the Review Warnings). For me I just recreated the view and copied across the annotation and the new view was fine. So then just deleted the old corrupt view...
Regards,
Chris.
Co-Founder | BIM Consultant | Software Designer  B. Arch)
Ok, I deleted the view and recreated it. That worked for 3 of the 4 elevations. the 4th view was only fixed after I deleted an inserted DWG. You were both very helpful. Thanks.
Grids at an Angle in Plan don't display in Elevation |
Thu, Apr 26, 2012 at 2:44:38 PM
2012 Design Review Incorrect views |
Fri, May 20, 2011 at 3:52:43 PM
Elevation consistancy issue in 2012 |
Tue, Dec 20, 2011 at 12:45:33 PM
revit 2012 - display option background disappeared and turned black |
Mon, Jun 25, 2012 at 4:48:13 PM
Abolute Elevation and Topo Points - Revit Architecture 2009 |
Wed, Feb 10, 2010 at 12:51:32 PM
Members: | 2022216 | Objects: | 22973 | Forum Posts: | 152199 | Job Listings: | 3 |
