60 Users Online (59 Members):
Forums >> Revit Building >> Technical Support >> disable work sharing
83 Posts No Rating |
I heard that in Revit 2012 you can stop work sharing if you no longer need worksets. How do you do that?
Open the file detached and the option will be there.
I have opened a file but cannot find a command to remove the worksets. Can you elaborate?
- Start Revit,
- Use the Open Project command,
- Navigate to your file,
- Highlight it,
- Select the "Detach from Central" Worksharing Option,
- Select Open,
- Choose "Detach and discard worksets"
- Save File (Worksets now gone)
Regards,
Chris.
Thank you Mr Spot! It solved my problem!
Work Sharing with School Projects |
Mon, Jan 16, 2012 at 8:48:37 PM
Violation Sharing |
Thu, May 24, 2012 at 8:33:18 AM
Best Practice to Sharing your Revit files with other disciplines or contractors |
Mon, Aug 10, 2009 at 2:50:49 PM
Sharing Models |
Tue, Jul 16, 2013 at 12:45:36 PM
File Sharing/Production |
Fri, Oct 24, 2008 at 6:07:13 PM
Members: | 2085021 | Objects: | 23131 | Forum Posts: | 152277 | Job Listings: | 3 |
