37 Users Online (35 Members):
Forums >> Revit Systems >> Technical Support >> mansard roof with cutoff level not working...
6 Posts No Rating |
i'm trying to make my mansard roof work. it seems to work on one side, but not on the other side when i mirror it over. as you can see from the inserted screenshot, the left side cuts off the roof correctly below the cutoff level and the right side cuts the roof off above the cutoff level. any help would be most appreciated!
thanks!
i'm using revit 2011
Somethings don't mirror well and sometimes it is better to mirror the sketch. In this case, maybe you should be following the advice given in this thread
: http://www.revitcity.com/forums.php?action=viewthread&thread_id=25289
Mansard roof madness |
Sat, Apr 1, 2017 at 4:54:07 AM
Roof Cutoff Level/Offset |
Fri, Apr 2, 2010 at 5:09:24 AM
Problem with Mansard Roof |
Wed, Mar 5, 2008 at 9:06:14 AM
Mansard Roof? |
Mon, Nov 26, 2018 at 2:45:22 AM
curved mansard roof |
Wed, Feb 18, 2015 at 3:56:01 PM
Members: | 2022349 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
