Forums >> Revit Building >> Technical Support >> Brick wall sweep surface pattern???
Wed, Sep 14, 2011 at 6:13:50 AM | Brick wall sweep surface pattern???
Pele
Pele Avatar
I have created a wall sweep along the lines of what i want, but how do I give the new sweep a brick pattern similar to the pattern on the wall?? ??
PS the sweep will only modify the returns at 3 of the 4 ends!! strange.
I will be scoring goals soon, I'm in the back line at the moment!
Cheers Dermot
www.dmbd.net
Wed, Sep 14, 2011 at 8:00:55 AM | Brick wall sweep surface pattern???
3.5 Stars: 395 Votes
When you create the sweep, assign the material in the type settings - see attached:
You can adjust the ends of the sweep.  If you want sweeps to join  around corners, do them together, not in separate sweep sessions.
Wed, Sep 14, 2011 at 9:07:27 PM | Brick wall sweep surface pattern???
Pele
Pele Avatar
Thanks a lot
That worked really well. As for the return part of the query, my intention for return was for a return at the end of a wall, (actually at the top of a column) not where a wall returns around a corner & continues as another wall in its own right.
So here is what i did for the present. I have a 270mm brick wall & i want the cols to show a brick detail (corbel), so I made a 110mm wall as a column (4 sides) then attached my 3 brick course detail to each side at the height of my openings so that it returns around all 4 corners. Probably what you would have done anyhow, but I worked it out for myself. I understand the brickwork intimately it is just telling the software that's the challenge.
Cheers Dermot
www.dmbd.net
Material surface pattern on a solid sweep?
Wed, Nov 17, 2010 at 2:48:49 PM
Revit 2015, Curved Wall Sweep Model Surface Pattern Inconsistant
Tue, Apr 28, 2015 at 4:09:13 PM
surface pattern visibility issues
Thu, Jan 5, 2006 at 3:13:47 PM
Surface pattern move/align/adjust problems [ 1 2 ]
Thu, Sep 17, 2020 at 10:29:33 AM
19
Sloped curved wall - brick pattern tapers with the wall...help!
Fri, May 18, 2012 at 8:07:12 AM
Page generation time: 1.2189
