Forums >> Revit Building >> Technical Support >> Rendered walkthrough is blurry
I exported a rendered walkthrough and the result was blurry. I did a 300 frame @ 15fps rendered walkthrough at I think "high" quality. It took about 15 hours to do, which I expected, but I was hoping for a little better quality result. I'm bidding on doing a 3d walkthrough for a historic house documentary, so I need to make sure I can achieve the quality that will be required. Any help would be appriciated!
Thank you!
You need to make sure that the dimensions of the 3D view are nice and big, say, 1920x1080 and not 600x400 pixels. I'd suggest rendering at medium quality for speed.
"Quality" of a render only affects things like shadow softness and reflection bounces. You won't notice any difference for ordinary renderings, except that they'll render 50% faster or so with medium quality.
As you set up your walkthrough, it'll ask you how you want to save it -- and what sort of compression you want to use. Revit uses some sort of simplistic Microsoft compression, and it really sucks. That's likely where your blurriness comes from. Instead, export an uncompressed AVI. It'll be gigabytes probably, or maybe just hundreds of megabytes, but then you can throw it into something like Windows Movie maker, (which is free and probably already installed on your machine) and then compress it with better options. Like "Best, for local playback" which will have almost no reduction in crispness, but make it 90% smaller in size.
probably the best way to compress a raw AVI into a good quality video.
@itsmyalterego
I'm having the same issue as pdoak. I tried doing as you suggested however, when I export the walkthrough as uncompressed, the video ends up glitching. (The video screen is split on a diagonal and shows to different walkthrough views playing) At least thats what happens when I play the video on my mac. However, I cant even play the rendered video on a windows machine. I get an error saying that the computer does not have enough memory and quits and its the only thing I have open.
Do you or anyone else know what might be going on?
Well, I recently had a MAJOR breakthrough with walkthroughs. I used a free 3rd party application to compress Revit exported video. It compresses video to literally 1/100th the diskspace. The program is called handbrake. The video quality is virtually lossless and blows revit's built-compression out of the water. I hope that helps!
I ended up only rendering my walkthroughs to single images, either jpg or tiff, and then combining to video later. This worked best for me as it removed the risk of losing the entire video if it messed up and having to redo. It also gave me a glimpse at the product before completion so I could see if there was anything missing through the video, and if so I could fix it easily and only correct the frames I needed. It also allowed me to put more than one machine on the job without a network, having one machine render frames 0-150 and the other 151-300, etc.
I've also found myself using 3ds max for some rendered walkthroughs, but the curve of learning that program well enough to get good results is daunting, well worth the time though, especially for anything interior.
I'll have to look into the 3rd party program suggested above, never used it.
best way to do a rendered Walkthrough video?(Student) |
Mon, Sep 19, 2016 at 6:31:24 AM
Rendered Walkthrough |
Thu, Jun 7, 2007 at 7:39:51 AM
Walkthrough in realistic view, not rendered |
Wed, Aug 27, 2014 at 12:00:38 PM
Blurry Render |
Wed, May 8, 2013 at 7:40:16 PM
rendered walkthrough? |
Mon, Jan 2, 2012 at 1:43:19 AM
Members: | 2030512 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
