Forums >> Revit Building >> Technical Support >> Floor opening issue
4 Posts No Rating |
I've been using Revit 8 Building for about a week now, seems to be just what I need, but....I've tried to cut an opening through a first floor, all seems to be OK but I cannot see throught the opening I've created, The outline is visible and will show a depth if I hover over it, I can see it on the cross section view, but why can't I see through the opening in the 3D view? Is there a view command (oops slipped back into AutoCAD mode there for a bit) or a box that needs ticking somewhere, must be obvious for all you old hands I bet, but its driving me mad.....
We would need more information to answer your question.
How did you cut your opening? - I prefer to just include it in the floor sketch rather than using an opening family.
4 Posts No Rating |
I used the opening function from the Design Bar...is that not right?
I can see through a floor hole. Make sure your view depth is deep enpugh to actually see something below.
4 Posts No Rating |
Yep, I'm well low enough, can see the perimeter of the hole but the interior of perimeter is "filled in" although if I hover over it, it highlights as a opening???
I'm sorry but you have done something wrong because this does work.
Could it be that you have a ceiling below the floor that is hiding the objects below?
Recheck your view depth.
Make sure something is there to see.
Cut a section through the opening to verify it is there.
4 Posts No Rating |
All sorted now, ripped off floor then redone seems to be fine now, (should have done this sooner I guess)
thanks for your help though, good to know there are people I can bounce things off
cheers
Floor and shaft opening issues |
Fri, Nov 4, 2016 at 3:41:51 PM
Opening issue |
Thu, Mar 1, 2007 at 10:36:43 AM
new opening in an existing floor |
Tue, May 15, 2007 at 3:49:39 PM
11
how to see through floor cut opening on plans? |
Thu, Nov 18, 2010 at 10:02:15 PM
Cant see stairs in opening in plan view |
Wed, Nov 26, 2014 at 10:35:35 AM
Members: | 2099198 | Objects: | 23170 | Forum Posts: | 152292 | Job Listings: | 3 |
