71 Users Online (70 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Revit 2011-putting openings in angled walls.
Fri, Sep 9, 2011 at 1:28:31 PM | Revit 2011-putting openings in angled walls.
hcjames570
Trying to build a mansard roof. Made side surface of roof by creating an angled plane as an In-Place Mass and followed by making mass surface into my wall type. This was successful but now i need to put openings into this newly created angled wall so that the intersecting walls containing windows can penetrate through.
How can i create an angled wall that has openings within it?
Fri, Sep 9, 2011 at 2:08:17 PM | Revit 2011-putting openings in angled walls.
If I need a wall, I create a wall, not a mass.  I extruded an in-place family at the right angle - wall category, then copied it, added my dormer walls - and of couse, because they are not masses, the walls all clean up.
Fri, Sep 9, 2011 at 2:49:57 PM | Revit 2011-putting openings in angled walls.
hcjames570
Ok,,,so when you say an in place family, could you elaborate a little more on that...
thank you very much.
Sat, Sep 10, 2011 at 5:45:27 AM | Revit 2011-putting openings in angled walls.
4 Stars: 202 Votes
Home > Component > Model In-Place
Angled Walls in Revit
Mon, Jan 12, 2015 at 8:48:26 AM
OPenings through multiple walls?
Mon, May 24, 2010 at 4:48:54 PM
Making Angled or canted walls
Tue, Jun 3, 2008 at 2:10:07 PM
Openings in (Structural) Walls Scheduling as Non-Bearing Walls
Thu, Feb 21, 2008 at 5:55:28 PM
Angled window opening in plan view
Thu, Aug 15, 2013 at 2:18:12 PM
11
Page generation time: 3.7141
