130 Users Online (128 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Creating a under ground level
Fri, Sep 9, 2011 at 12:45:19 PM | Creating a under ground level
gastonverdicchio
Hi there,
I'm experiencing problems with an under floor carpark. Please have a look to the image attached
1- How can I extend the height of the ground pattern under the F.F. level -1?
2- How can I get rid of the ground pattern inside the carpark area?
Many thanks in advance
Gaston
Fri, Sep 9, 2011 at 12:47:45 PM | Creating a under ground level
You need to create a pad on your site.  This will create a hole for your building.  Read how to in your HELP - search PAD.
Tue, Sep 13, 2011 at 2:43:29 AM | Creating a under ground level
gastonverdicchio
Many thanks WWhub, It did work but still I dont know how to change the earth graphism height on section,
G.
Tue, Sep 13, 2011 at 7:11:43 AM | Creating a under ground level
You posted the same image as first time.  And you did not ask about the earth poche.  The poche depth is controlled from the massing & site tab, model site pulldown, site settings.
Tue, Sep 13, 2011 at 12:20:18 PM | Creating a under ground level
gastonverdicchio
Great WWHub, many thanks,
G.
Rendering problems Ground plane not changing
Wed, Mar 7, 2012 at 1:42:47 PM
Component wont show up in plan above ground
Sat, Mar 3, 2012 at 1:35:40 PM
Rendering Ground Planes showing up when i dont want them to
Wed, May 10, 2006 at 7:14:44 AM
Toposurface
Fri, Nov 20, 2015 at 11:56:28 AM
Existing and proposed ground level
Mon, Aug 4, 2014 at 6:35:49 PM
Page generation time: 16.5523
