Forums >> Revit Building >> Technical Support >> File saves
160 Posts No Rating |
Revit saves quite a few files in whatever folder I am working in, up to five. Is this normal, surely it only needs to save one or maybe two. Is there a setting to arrange how many I want or is there a reason for this amount.
I will be scoring goals soon, I'm in the back line at the moment!
Cheers Dermot
www.dmbd.net |
Under your Revit R ... Options. Journal files.
are you talking about the files witn the 4 digit extensions?
Yes Coreed the file name is DA-A01 and although I have not created nowhere near this amount of files I have
DA-A01.0069.rvt, DA-A01.0070.rvt, DA-A01.0071.rvt, DA-A01.0069.rvt and DA-A01 in the folder.
I will have a look under options Hub, but at the moment that dialog box open has frozen my Revit.
Thanks folks
Cheers Dermot
www.dmbd.net |
I think this solve your problem, correct?
That's correct Typhoon. Now next question? why do I need more than one, & can I tell the backup to be backed up to somewhere else, like my back up disk?? But that backs up periodically anyhow, hhmmn.
Cheers Dermot
www.dmbd.net |
Can't share central file |
Mon, Nov 23, 2009 at 4:07:18 PM
Server for Worksets |
Fri, Jul 14, 2006 at 4:43:04 PM
Automatic saves! |
Wed, May 31, 2006 at 6:23:08 PM
Central File Too Big |
Mon, May 19, 2008 at 5:01:28 PM
Auto saves |
Wed, Dec 19, 2007 at 2:22:54 PM
Members: | 2118417 | Objects: | 23198 | Forum Posts: | 152298 | Job Listings: | 3 |
