58 Users Online (55 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> elevations have gone transparent
Wed, Sep 7, 2011 at 12:48:17 PM | elevations have gone transparent
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
ive seen 3d views go transparent before and i know the fix for that but I have a project that all my elevations are transparent. ive tried quite a few fixes. Has anyone ever experienced the same problem?
oh yeah and it prints fine, the transparency is only while looking at it on screen
Edited on: Wed, Sep 7, 2011 at 12:50:11 PM
Wed, Sep 7, 2011 at 12:50:47 PM | elevations have gone transparent
Are you sure the wall category has not been over-ridden to transparent in VG?
Wed, Sep 7, 2011 at 1:02:06 PM | elevations have gone transparent
alabaster2513
3.5 Stars: 25 Votes
yeah i check all that and the materials. its so weird, its only the overall building elevations. our 200 interior elevations are fine. if i copy the elevation the new copy is transparent. If i create a new elevation from scratch it is not transparent. I thought it might just be my machine but it's happening to everyone
Wed, Sep 7, 2011 at 1:09:22 PM | elevations have gone transparent
It is the view.... that is what your tests have shown.  VG over-rides - phases maybe, by element maybe - by ctaegory maybe....BUT - IT is definitly a user created problem.
Wed, Sep 7, 2011 at 1:14:59 PM | elevations have gone transparent
alabaster2513
3.5 Stars: 25 Votes
I got the east elevation to show normal by changing the far clipping from no clip to clip without line but that only work on that elevation. does not change anything on the others.
Fri, Sep 9, 2011 at 11:28:00 AM | elevations have gone transparent
alabaster2513
3.5 Stars: 25 Votes
problem solved. someone inserted a dwg from food service that had proxies and was 3000 ft from 0,0. just deleted it, moved it and exploded it in cad and reinserted.
Fri, Sep 9, 2011 at 11:35:26 AM | elevations have gone transparent
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
Interesting fix. I have had this problem before. I will look for an inserted object. What was the object that caused the problem. Maybe I have the same?
Fri, Sep 9, 2011 at 11:46:59 AM | elevations have gone transparent
alabaster2513
3.5 Stars: 25 Votes
it was the entire kitchen layout. some of the objects were 3d objects with hyperlinked pdfs. i think exploding everything was the key fix
Fri, Sep 9, 2011 at 1:35:53 PM | elevations have gone transparent
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
Ok, thanks
Wed, Jun 6, 2012 at 6:02:04 PM | elevations have gone transparent
richardk
So how did you fix the 3d views that have a transparent object?  I have a building where only one wall is showing transparent in a 3d view.  i have check the object settings, no transparency.  Checked the VG settings for walls, no transparency.  Checked the category settings, no transparency.  Not sure what else to check.  Thanks
Transparent object
Tue, Sep 14, 2010 at 1:18:34 PM
Creating transparent material such as 3FORM
Wed, Aug 26, 2009 at 8:09:06 AM
Transparency in elevations still no bueno?
Fri, Feb 20, 2009 at 11:11:13 AM
MAKING DEMOLISHED OBJECTS TRANSPARENT
Tue, Mar 12, 2013 at 2:02:34 PM
Interior Elevations appear transparent
Tue, Feb 17, 2009 at 2:22:17 PM
Page generation time: 0.5862
