110 Users Online (109 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Elements missing from Material Take Off Schedule
Wed, Sep 7, 2011 at 4:38:27 AM | Elements missing from Material Take Off Schedule
lewis001
I've noticed that if an element doesnt have a material applied to it then it doesnt show up in the material take off schedules. Im using these schedules to work out the weight of steel in my project and it seems rather light! is there a way to find all the elements in the project that doesnt have a material applied to it?
thanks!
Wed, Sep 7, 2011 at 9:49:35 AM | Elements missing from Material Take Off Schedule
emgeeo
3.5 Stars: 7 Votes
I am guessing the material parameter is currently set to By Cateogry, but your default material is unassigned.
Here's what you could do.
1.  Go to the object styles (VV->Object Styles) and change the default materials to something recognizably wrong (a default mass material would work just fine.  If a default material is already set, verify that the correct material is being used.
2.  Check your schedule, it should be there now.
3.  Either change the properties in the project browser, or use the show in model option (which selects the item as well)
Edited on: Wed, Sep 7, 2011 at 9:52:55 AM
Schedule material mark in schedule type other than material Schedule?
Wed, Jun 22, 2011 at 3:59:07 PM
Schedule material mark in door schedule - Revit 2014
Fri, Jan 19, 2018 at 2:57:03 PM
Elements Missing in Render Image
Mon, Sep 27, 2010 at 7:21:17 AM
Material Takeoff problems
Thu, Oct 12, 2017 at 5:53:40 PM
Material schedule not picking up materials in railing object
Fri, May 6, 2011 at 4:03:35 PM
Page generation time: 0.7707
