91 Users Online (90 Members):
Forums >> Community >> Newbies >> Confusing CONSTRAINS
6 Posts No Rating |
hI, I get in trouble with my constrains ![Smile](/images/smiles/smile.gif)
I draw a 4 sided shape: one side is an arc, other 3 are straight and perpendicular. (Arc is the bottom).
Then I dimension and constrain the sides.
The idea is that if I move the top up and down then the rest of the shape follows (because the dimensions of the sides that constrain the top and bottom are constrained).
However when I attempt to move the top or the bottom, it doesn't work.
(This is part of an exercise from a book. When I did it first time this part worked easy, but I messed up on other tasks. now that I figured out how to do the rest of the exercise I can't manage the constrains . Perhaps I messed up a setting somewhere. It is tough to be a newbie )
Thank you
Denn15
![vector25 Avatar](user_avatar/254470.jpg)
![2.5 Stars: 7 Votes](/images/stars_2.5.gif) |
those two locks are the constraints- click on them and unlock them and there won't be no constraints.. or if you click on that "remove constraints" button- that will unlock them for you..
6 Posts No Rating |
for me the point is to keep the constrains, so that the whole shape moves when I move only the top.
(The whole idea was to glue the top piece to a level mark, so when the level mark moves, the shape moves with it (the shape is being part of revolve void that was cutting multiple walls. To keep my question simple, I dropped the unrelated info from my original question.)
lock a grid line to the top and move the grid line and it all moves..
permanently infected revit city forum software won't post a jpeg image..
Edited on: Wed, Sep 7, 2011 at 4:28:09 AM
6 Posts No Rating |
Perhaps I'm not being very clear about my problem.
My problem is that after I constrain the sides, moving the top - gives me a mistake! - it breaks the constrains!
(mistake text is in the image)
attaching the top line to a level is no problem.
Material Update Confusing |
Sat, Jul 26, 2008 at 7:50:28 PM
Door family construction |
Mon, Feb 15, 2010 at 9:31:28 AM
copying system panels between projects - how should it be done? |
Wed, May 29, 2013 at 7:06:51 PM
groups - need help |
Wed, Dec 16, 2009 at 8:08:32 PM
Cylinder with a angle |
Tue, Jun 16, 2009 at 10:30:58 PM
Members: | 2017117 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
