158 Users Online (157 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Wall heights - change all heights simultaneously
Tue, Sep 6, 2011 at 4:37:46 PM | Wall heights - change all heights simultaneously
mshrader
I have TWO types of walls in my model (beyond curtain walls).
I have two wall heights 8'6"' and 10'9"'. I made two different types of walls for this purpose. However, I built the walls at a generic height (11') didn't know the dimensions until a few days ago. I now want to change the height from 11' to 10'9" for my 2nd wall type.  What is the best way to do, (i.e most efficient) vs. clicking on each wall and changing the height to 10'9"? I've tried match properties but its not efficient. Also if I change my level to 10'9" then my ceiling doesn't show up in RCP 1.
Thank you in advance!
M
Tue, Sep 6, 2011 at 6:41:37 PM | Wall heights - change all heights simultaneously
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
Create multiple levels, and control from there the height of that kind of elements.
The faster way to go is--> select all--> filter type--> wall. Then isolate element --> select all the walls that are changing--> set the height to "level x" where level x is the new height. You dont really need two types, only one type with different heights, so change all those walls into a single walltype.
Wed, Sep 7, 2011 at 7:43:25 AM | Wall heights - change all heights simultaneously
emgeeo
3.5 Stars: 7 Votes
The way you've set things up doesn't necessitate any sort of filtering or level-changing.  Just use the select all command.
Select the wall type -> Right-Click -> Select All Instances -> In entire project
You've now selected all the walls of that particular type in the entire project.  Change the wall properties from there.
Also, you don't have to have a single wall type either, what you've done works.  It may not be ideal from a model/information maintenance standpoint, but it works.  Each method has it's advantages and disadvantages.
Edited on: Wed, Sep 7, 2011 at 7:46:39 AM
Why do all my Wall Heights default to 20'-0" !!
Wed, Apr 26, 2006 at 4:31:22 PM
one roof two wall heights
Mon, Apr 6, 2009 at 11:35:00 PM
Change start and end heights of elements in radial array
Tue, Sep 20, 2016 at 7:06:50 AM
Schedule Wall Heights
Wed, Apr 14, 2010 at 10:45:26 AM
changing multiple level heights
Wed, Oct 31, 2012 at 9:54:12 AM
Page generation time: 2.4168
