43 Users Online (41 Members):
Forums >> Revit Building >> Technical Support >> Visual override of Shaft Opening
3 Posts No Rating |
I have made a view template to represent simple floor plans for marketing purposes. This template makes all the walls black and gets rid of tags etc.
I have tried to 'hide' the shaft openings within the plans by blacking them out within the view template so they appear like the walls, but I am having no luck, the shaft only appears black when I have it selected, otherwise it is the default template.
Has anybody had this problem or have any idea what I am doing wrong?
![3.5 Stars: 7 Votes](/images/stars_3.5.gif) |
Someone correct me if I am wrong, but I belive you cannot over-ride the graphics of shaft openings.
You could create a filled-region group and place it on each appropriate level...
Undoing Shaft Opening |
Fri, Mar 2, 2007 at 12:00:35 PM
Shaft Opening Phase Visibility |
Mon, Jan 2, 2017 at 9:42:25 AM
A Floor That Can't Be Penetrated by Shaft Opening |
Thu, Feb 20, 2014 at 2:30:48 PM
Floor and shaft opening issues |
Fri, Nov 4, 2016 at 3:41:50 PM
Symbolic Lines not showing up in Shaft Openings |
Thu, Jul 3, 2008 at 11:08:46 AM
Members: | 2022374 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
