115 Users Online (113 Members):
Forums >> Revit Structure >> Technical Support >> Creating Columns
1 Posts No Rating |
Hi I am new to revit and am havng trouble creating a column. I am trying to create an indutrial column with an i-beam and concrete base. How do I combine these two elements to create a successful column? Please help!!!!!
![3.5 Stars: 7 Votes](/images/stars_3.5.gif) |
You need to create a family, you have a couple of options:
1. Create a single family with all the geometry
2. Create two families. One for the concrete base nested into the steel-column family.
Do you know how to create/edit families?
Why don't you just place seperate columns?
Or are you just protecting the base of a steel column with a concrete surround?
![AbsoluteBIM Avatar](user_avatar/255025.jpg)
![3.5 Stars: 3 Votes](/images/stars_3.5.gif) |
Can you just used the 'isolated foundation' function after placing the column?
HB&G Columns |
Thu, Jan 22, 2009 at 4:30:03 PM
hidden columns |
Fri, Mar 26, 2010 at 10:53:36 AM
Showing columns from the floor above |
Mon, Jun 9, 2008 at 1:49:48 PM
Structural Columns not cutting walls |
Mon, Jan 4, 2016 at 4:13:25 PM
Slab cutting out columns! Any way to stop this? |
Wed, Jun 11, 2014 at 4:58:17 PM
Members: | 2017318 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
