83 Users Online (81 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Detail reference tags
Tue, Nov 29, 2005 at 4:47:01 PM | Detail reference tags
Surfrusty777
I have a reflected ceiling plan legend that has a number of keynotes. After the keynote text description in the same line we put a detail reference tag. At least that is how we did it in CAD. Can something similar be done in revit? I have a few of our standard details imported into drafting views. How do I reference or link them to a reference tag? Thanks, Mark
Tue, Nov 29, 2005 at 4:51:33 PM | RE: Detail reference tags
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You can create callouts/sections/elevations and use the reference other view option to select which view you would like to have the reference tag link to... Is this what you're after?
Tue, Nov 29, 2005 at 4:59:11 PM | RE: Detail reference tags
Surfrusty777
Maybe...lol...Since it is a standard detail it isn't referenced on any floor plan so how can I create a callout for it? I mean I have used the callout tool. But I just want a reference tagonly that I can place in my legend/notes that is linked to a detail that will appear on a standard detail Sorry, I know I'm a noob! Thanks! Mark
Tue, Nov 29, 2005 at 5:07:10 PM | RE: Detail reference tags
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Hmm, I don't think you can place view tags in legend views... You can in a drafting view however. Just make sure you have the "reference other view" option ticked (in a drafting view this is on by default). HTH.
Tue, Feb 7, 2017 at 11:22:09 AM | Detail reference tags
cboersen
In 2013 and newer you can.  Here is a tutorial
http://revitoped.blogspot.com/2012/03/revit-2013-view-references.html
Reference View Tags not referencing actual detail number
Tue, Sep 30, 2008 at 3:58:23 PM
additional detail tags
Thu, Apr 19, 2012 at 3:27:32 PM
Detail tags
Tue, Feb 11, 2014 at 10:10:28 AM
Two Detail Tags with Same reference Sht & Dwg
Fri, May 23, 2008 at 10:23:04 AM
Hiding Detail Tags in other views [ 1 2 ]
Thu, Jan 21, 2010 at 5:26:48 PM
21
Page generation time: 0.4972
