21 Users Online (20 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Extended 2 1/2" joist end with a 5"+ seat bearing?
Fri, Sep 2, 2011 at 7:53:05 AM | Extended 2 1/2" joist end with a 5"+ seat bearing?
seniorcad143
1 Stars: 1 Votes
How do you make a 2 1/2" joist end extension on a sloping joist when you have a 5"+ seat bearing on a beam?
Also - how do I get the joist end extension to show up in plan?
Also - I am new to Revit so please spell it out for me :-)
Yeesh - Where is My Cad
Tue, Sep 27, 2011 at 10:25:25 AM | Extended 2 1/2" joist end with a 5"+ seat bearing?
seniorcad143
1 Stars: 1 Votes
Does anyone know the answer to this - or is there no answer?
Wed, Sep 28, 2011 at 11:37:41 PM | Extended 2 1/2" joist end with a 5"+ seat bearing?
revitaggie
Not quite sure what you are asking but I'll take a shot at it.
This thread might have the answer you are looking for:
http://www.revitcity.com/forums.php?action=viewthread&thread_id=15647
The joist families that come with revit do not support sloping joist seats. As far as seat depth and top chord extensions are concerned; seat depth is a type parameter(must click "edit type" to change this. I recommend creating a duplicate type for the seperate seat depth) I believe, and top chord extensions are an instance parameter listed as "end extension".
Thu, Sep 29, 2011 at 6:43:09 AM | Extended 2 1/2" joist end with a 5"+ seat bearing?
seniorcad143
1 Stars: 1 Votes
OK - thanks.
But the joist end extension doesn't show up in plan view, is htere anyway to get it to show up?
Thu, Sep 29, 2011 at 11:31:40 AM | Extended 2 1/2" joist end with a 5"+ seat bearing?
revitaggie
It may not show up in course view but it should show in medium or fine.
Thu, Sep 29, 2011 at 1:15:44 PM | Extended 2 1/2" joist end with a 5"+ seat bearing?
seniorcad143
1 Stars: 1 Votes
The only problem with showing the plan work in medium or fine is that is shows the framing members top chord thickness.  In plan work I want the joists and beams to be represented by a single line.
Any suggestions.
Thu, Sep 29, 2011 at 2:17:34 PM | Extended 2 1/2" joist end with a 5"+ seat bearing?
seniorcad143
1 Stars: 1 Votes
revitaggie - how did you learn the "lanquage" to use to type into the family types for the example you gave int this post:
It would be very helpful for me to understand what you entered into the formula area.
Thu, Sep 29, 2011 at 3:07:20 PM | Extended 2 1/2" joist end with a 5"+ seat bearing?
revitaggie
It is almost identical to what you would use in excel.
Unfortunately copyright laws prevent me from uploading those specific families.
double pitched top chord joist seats
Tue, Feb 15, 2011 at 3:37:51 PM
Joist Seat Elevation?? HELP!!
Fri, Apr 11, 2008 at 10:35:49 AM
Different seat depths same joist?
Wed, Nov 11, 2009 at 6:32:10 PM
bar joist seat depths
Mon, Nov 21, 2011 at 2:49:44 PM
Joist Seats on sloped joists
Wed, Oct 24, 2012 at 1:27:46 PM
13
Page generation time: 0.7308
