77 Users Online (75 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Scheduling Compound Walls
Tue, Nov 29, 2005 at 1:34:08 PM | Scheduling Compound Walls
Jadranko
Is it possible to schedule quantities of individual materials of which the compound walls are made of? For instance, some walls are composed of 30 cm thick brick core and 7cm thick thermal insulation, and some others are composed of 12 cm brick core and 1 cm plaster on each side. I'd like to generate the schedule with quantities of brick, insulation and plaster used in those walls.
Tue, Nov 29, 2005 at 4:50:19 PM | RE: Scheduling Compound Walls
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
No. They would need to be constructed as separate elements.
Wed, Nov 30, 2005 at 7:05:54 AM | RE: Scheduling Compound Walls
Jadranko
Thanks for the quick response Mr. Spot. Do you know any other method or workaround? Has anyone tried to extract information on used materials through ODBC export?
Real compound walls
Sun, Feb 20, 2005 at 8:26:42 PM
non compound wall acting like compound wall
Mon, Feb 20, 2012 at 2:30:22 PM
Partial Vertical Reveals in Vertically Compound Walls
Thu, Jul 24, 2008 at 1:04:53 PM
Compound Walls
Thu, Apr 3, 2008 at 4:55:17 PM
Doors/Windows in Compound Surfaces
Wed, May 31, 2006 at 10:06:21 AM
Page generation time: 1.6482
