78 Users Online (76 Members):
Forums >> Revit Building >> Technical Support >> Visibility Parameter Formula based on 0.5m Lengths
2 Posts No Rating |
Hi
I need some help with a formula that does the following:
SCENARIO: Building Basic Truss Components in 1.0m, 0.5m lengths
We've created a Truss component that has a Length parameter allowing us to type in the length, and the component adjusts accordingly (usual stuff). Within this, we have a set of Support Beams that array if the length is over 1.0m - however, the grouped supports are 1.0m in length and therefore stick out the end of all 0.5m lengths.
Is there way for me to create a 0.5m support and have that display for all lengths of 0.5m value?
I hope that makes sense... see attached pic.
Thanks.
![3.5 Stars: 7 Votes](/images/stars_3.5.gif) |
Can't you just use a conditional statement to control the visibility? I'm pretty sure you can.
If you have the weld-symbol family, you can find an example there. Otherwise, I'll dig around and post it.
visibility formula |
Thu, Jan 16, 2014 at 3:28:44 PM
Visibility Formula in Family Parameters |
Mon, Apr 24, 2017 at 6:06:35 PM
One family parameter has formula one has none |
Wed, Jun 25, 2014 at 1:05:54 PM
Referencing a Shared Parameter in a Family parameter formula. |
Thu, Jan 29, 2015 at 1:26:24 PM
NOT Parameter Formula Question |
Fri, Apr 10, 2009 at 8:30:17 AM
Members: | 2022486 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
