73 Users Online (71 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Placing Ext wall on foundation wall
Wed, Aug 31, 2011 at 1:05:48 PM | Placing Ext wall on foundation wall
seniorcad143
1 Stars: 1 Votes
I am having a problem placing an exterior 1'-4" thick Brick and Cmu wall ontop of my foundation wall.  My foundation wall top is at the ground floor level and I have tried to place the exterior 16" thick wall on top of it with a height to bmd.  it keeps telling me this:
None of the created elements are visible in Structural Plan: GROUND FLR View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings.
Can someone please let me know what I am doing. the visibility range is 4' above the ground floor and the cut plane is 1' above.  Did I click something I should not have.
(Oh - I also created the wall type myself.  I also tried using one of the generic walls and it deletes my dimension line and still doesn't place the wall)
Also - sorry in advance, I am new at revit.
Yeesh - Where is My Cad
Wed, Aug 31, 2011 at 1:17:34 PM | Placing Ext wall on foundation wall
4 Stars: 202 Votes
In View range, change the "View Depth" to "Level below"
Wed, Aug 31, 2011 at 1:31:52 PM | Placing Ext wall on foundation wall
seniorcad143
1 Stars: 1 Votes
OK - just tried that and it still won't put it in and it leaves this note:
Highlighted walls overlap. One of them may be ignored when Revit finds room boundaries. Use Cut Geometry to embed one wall within the other.
I don't understand this because my foundation walls stop at the ground floor.  I do have my columns in, are they talking about my coulmns?
Wed, Aug 31, 2011 at 1:40:19 PM | Placing Ext wall on foundation wall
4 Stars: 202 Votes
Are you sure you have those walls with "Base Offset" to "0"???
Wed, Aug 31, 2011 at 1:57:40 PM | Placing Ext wall on foundation wall
seniorcad143
1 Stars: 1 Votes
I have in the Instance Properties Box:
Base Constraint - Ground Flr
Base Offset - 0' 0"
Top Constraint - Up to Level: BMD
Top Offset - 0' 0"
Wed, Aug 31, 2011 at 2:29:58 PM | Placing Ext wall on foundation wall
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
More than likely the Discipline for the view is set to "structural" it needs to be set to "architectural" or "coordination" for architectural walls to show up.
Wed, Aug 31, 2011 at 2:56:57 PM | Placing Ext wall on foundation wall
seniorcad143
1 Stars: 1 Votes
"BINGO"
But...   How do I get the wall to show up in my sections - will changing the discipline to architectural mess up anything, will some of the structural not show up?
And what if I want the cmu walls to show up on the interior, just say they are structural?
Wed, Aug 31, 2011 at 3:02:11 PM | Placing Ext wall on foundation wall
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
You can use the coordination setting to show both. You can also set the wall type to structural. I believe the structural walls will show in sections.
Wed, Aug 31, 2011 at 3:12:30 PM | Placing Ext wall on foundation wall
seniorcad143
1 Stars: 1 Votes
Thanks! - I will try both ways and I guess see which works best for each job.
One last question - do you find that you leave the plans at coordination most of the time or structural?
Wed, Aug 31, 2011 at 3:18:43 PM | Placing Ext wall on foundation wall
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
Actually I work for an architectural firm so I use architectural most of the time. Foundation plans are about the only one I use structural or coordination for.
Edited on: Wed, Aug 31, 2011 at 3:19:01 PM
Thu, Sep 1, 2011 at 11:17:57 AM | Placing Ext wall on foundation wall
#11
pdoug
3 Stars: 2 Votes
Assuming you are working in Revit Structure...leave your settings to structural and set the wall type to bearing, then it will show up in all views.
Foundation Wall Gaps @ Doors
Wed, Jun 11, 2008 at 4:47:53 PM
WALL FOUNDATION CORNER
Tue, May 5, 2015 at 10:17:13 AM
Wall Footings and Foundation extrusions
Wed, Jun 8, 2016 at 7:55:55 AM
Offset of the Wall foundation from the wall in Height
Sun, May 12, 2019 at 2:43:16 PM
Split Region Wall Foundation Issues
Wed, Jun 1, 2011 at 5:36:26 PM
Page generation time: 0.8804
