47 Users Online (46 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Beam Annotations
Wed, Aug 31, 2011 at 7:34:09 AM | Beam Annotations
gregroberson
gregroberson Avatar
I have a structural floor plan in RST 2011, And am modifying the elements to be joists.  I can not longer use the bam annotations tool to indentify their top os steel elevation.  Is that correct?
Wed, Aug 31, 2011 at 11:42:21 AM | Beam Annotations
pdoug
3 Stars: 2 Votes
I don't see why you cannot.  I just tried a joist in my model which was also part of a beam system and it worked.  Make sure you check off the setting to replace what is already there.
Hope this helps!
Fri, Sep 2, 2011 at 8:12:56 AM | Beam Annotations
gregroberson
gregroberson Avatar
It worked when you changed the family toa Bar Joist or changed the structural usage?
Fri, Sep 2, 2011 at 8:32:04 AM | Beam Annotations
pdoug
3 Stars: 2 Votes
For the joist I tried before replying to you the first time the joist used was a light-gage mtl joist.  I just modified some joists in my model to change the structural usage and that didn't matter, it still reported what I wanted it to.
What are members you are changing to joists?  Anymore info you can provide would be helpful.
Fri, Sep 2, 2011 at 4:32:38 PM | Beam Annotations
gregroberson
gregroberson Avatar
i HAVE A BEAM IN PLAN WITH bEAM ANNOTATIONS ADDED USING THE BEAM ANNOTATION TOOL.  tHEY WERE WIDE FLANGE MEMBERS.  HOWEVER, WHEN i CHANGE ONE TO A BAR JOIST, THE ELEVATION DISAPPEARS...IF I CHNGE IT BACK TO A BEAM OTHER THAT A JOIST...THERE IS THE SPOT ELEVATION AGAIN.
Meeting Beam Systems to Glulam Beam
Wed, Jun 20, 2012 at 10:34:17 AM
Precast Beam System not sitting on beam
Thu, Jan 10, 2013 at 11:45:49 AM
Steel Beam to Beam Connection
Fri, Jun 18, 2010 at 1:54:37 PM
Beam & Beam systems
Tue, Oct 21, 2008 at 4:36:55 PM
Can't load annotations
Wed, Jun 27, 2007 at 4:23:06 PM
Page generation time: 0.7719
