121 Users Online (119 Members):
Forums >> Revit Building >> Technical Support >> Interior Remodel
1 Posts No Rating |
I am developing a model for an existing building in which we are removing some walls and doors and adding new walls and doors. I am trying to figure out how to show the new walls with a solid fill in the floor plan view. Also how to show new doors so that they stand out compared to the existing doors. I found that the wall fill can be added but only under coarse detail level. Is there another way to achieve this? The main question is about changing the appearance of the new doors opposed to the existing doors. Any help would be great. Thanks
By default, existing doors should be greyed out, if your are using the appropriate phase filter...
Checkout your phase settings to adjust overrides to your requirements.
For the new walls in there properties just ensure the material that's applied to them has the appropriate solid fill cut pattern.
storefront remodel procedures |
Thu, Mar 5, 2009 at 1:06:45 PM
Showing before and after exterior finishes on a remodel... |
Thu, Sep 11, 2008 at 3:34:26 PM
Remodel confusion |
Wed, Jul 8, 2009 at 3:33:57 PM
Phasing remodel roof... |
Sun, Jul 22, 2007 at 5:28:43 PM
Interior Elevations |
Wed, Jul 11, 2007 at 5:42:18 PM
Members: | 2017329 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
