37 Users Online (36 Members):
Forums >> Revit Building >> Technical Support >> Partial Wall component
8 Posts No Rating |
How do you show tile on a wall only 4 feet high while the wall is 8 foot hight, within a wall type?
Thanks...
Checkout the compound wall tutorials or stacked walls in revit. These were designed for such occurences.
33 Posts No Rating |
If you want a good section as part of the end result, I do such stacking by using different wall types nested within a curtain wall. Create a generic curtain wall. Divide it up with grid lines, pick a panel created by the grid lines, then select a wall type instead of a panel type. I like it much better than stacked walls, and it is great for isolated objects in the middle of the wall that still work right in section.
partial wall miter below winder [ 1 2 ] |
Sun, May 3, 2009 at 12:21:40 PM
20
component with material and recess wall |
Thu, Sep 10, 2015 at 7:22:23 AM
Converting a component into a wall? |
Tue, Apr 6, 2010 at 9:30:33 AM
Overall Plans and Partial Plans ... looking for Best Practice [ 1 2 ] |
Sun, Jul 21, 2019 at 7:44:21 AM
15
ARCH OPENING IN IN PLACE WALL COMPONENT |
Thu, Jun 14, 2012 at 2:04:06 PM
Members: | 2066379 | Objects: | 23085 | Forum Posts: | 152257 | Job Listings: | 3 |
