95 Users Online (94 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> File size
Tue, Nov 29, 2005 at 12:47:51 PM | File size
trich00
Does anyone know how to maintain a reasonable file size; under 50mb or max 100mb? We have remove all unsued objects - What causes the file size to grow? I hope Revit will address this in the next issue.
Tue, Nov 29, 2005 at 5:02:50 PM | RE: File size
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Items bloating file sizes from my experience are: Excess/unused views (have a big effect) In-place families (avoid using if there is more than 1 element) Captured renderings (don't capture them and save them out) Remove excess loaded dwg and images. HTH.
Tue, Nov 29, 2005 at 5:44:11 PM | RE: File size
eldados
eldados Avatar
4.5 Stars: 8 Votes
as well as removing all 3D views you don't need, avoid arraying in place family, or external families, and in regard to speed in your view, avoid grouping lot's of detail lines... Smile
Integrator
KarelCAD
Tue, Nov 29, 2005 at 6:02:31 PM | RE: File size
geoffy
Linking files such as your site plans will help keep those file sizes down too.
AutoCAD & Revit TAFE teacher from regional Australia
Wed, Nov 30, 2005 at 6:23:26 PM | RE: File size
krmccurdy
If it's for transmittal, etc. I find the "compact file" feature under "options" when you do a save as works great. I've knocked off a third of the capacity when stripping the file of everything else won't due more for me.
Fri, Nov 16, 2007 at 11:23:09 AM | File size
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Does having more Ceiling plans, and floor plans, and sheets make a difference.  I have all the default stuff in there and haven't deleted it.  My file is only 17MB and it's slowing down.  Any ideas how to fix the drag on it?  Is it a RAM issue?  I have 2.5 GB of RAM.  Any ideas?  I have a decent about of 3D views but that's cuz we're using them.  We have worksets setup but we don't actually place objects on worksets just because it's a residence and not a huge model so we didn't think we need to differnet worksets.  We only have it enabled so multiple people can use it at the same time.  Any ideas on how to speed it up?
Thanks,
Lorne
Denver, CO
Revit Architecture
Fri, Nov 16, 2007 at 12:07:58 PM | File size
ebtaylor
3 Stars: 2 Votes
I have found that fixing problems from review warnings has helped the performance of my model. Not sure exactly why but it has.
Fri, Nov 16, 2007 at 2:43:48 PM | File size
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
What are review warnings?
Denver, CO
Revit Architecture
File size and performance with multiple instances of 3d families
Wed, May 26, 2010 at 4:10:42 PM
decrease file size
Tue, Nov 16, 2010 at 2:06:43 PM
Saved File Size
Mon, Feb 15, 2010 at 6:17:13 AM
DWF File Size
Fri, Oct 26, 2007 at 9:52:18 AM
reducing file size
Wed, Oct 11, 2006 at 4:01:48 PM
Page generation time: 1.5482
