47 Users Online (45 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> Newbies >> Revit architecture on Macbook pro i7 with flashdrive7??
Sat, Aug 27, 2011 at 11:53:03 AM | Revit architecture on Macbook pro i7 with flashdrive7??
BlueFairy
has anyone used Revit on Macbook pro with i7 and Flashdrive?  What kind of problems will I run into with a flashdrive....?  Should I just get the regular drive?  What is the performance like?
Wed, Oct 19, 2011 at 3:19:03 PM | Revit architecture on Macbook pro i7 with flashdrive7??
rkitect
rkitect Avatar
4 Stars: 29 Votes
Not sure I understand what you mean by using with a flashdrive. You mean running revit from a USB stick?
Wed, Oct 19, 2011 at 4:11:10 PM | Revit architecture on Macbook pro i7 with flashdrive7??
BlueFairy
Apparently all apple computers want to start moving to flashdrives... Like macbook air.  Does not use a regular SATA? drive anymore.
Wed, Oct 19, 2011 at 4:44:28 PM | Revit architecture on Macbook pro i7 with flashdrive7??
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
solid state drives you mean, solid state drives are infinitely better than SATA
Edited on: Wed, Oct 19, 2011 at 4:45:17 PM
Wed, Oct 19, 2011 at 5:11:23 PM | Revit architecture on Macbook pro i7 with flashdrive7??
rkitect
rkitect Avatar
4 Stars: 29 Votes
Ah, in that case, no, there will be no issues with running Revit from this. In fact you will see signiificant improvement, especially on low RAM machine such as laptops where memory swap to the SSD would be incredibly fast.
Revit architecture for Macbook pro? [ 1 2 3 ]
Thu, Oct 27, 2011 at 7:25:36 AM
39
Using Revit with MacBook Pro 15" & Parallels [ 1 2 ]
Sat, Sep 19, 2015 at 8:06:26 PM
19
LICENSE PROBLEMS USING REVIT IN A MACBOOK PRO
Thu, Feb 19, 2009 at 11:40:08 PM
registration problems on macbook pro
Fri, Jan 23, 2009 at 11:14:27 PM
Display weirdness using Macbook Pro with exterior monitor
Fri, Nov 14, 2014 at 11:39:26 PM
Page generation time: 1.6734
