72 Users Online (70 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Wishlist >> walls and columns
Fri, Aug 26, 2011 at 2:26:07 PM | walls and columns
WerewolfV
It'd be very nice to have walls (any walls) not to cut thru columns.  I can't come up with a condition when any wall, even a bearing one, interferes with a column.
On a different topic.  Is it possible to include doors for CMU, Cast-in-place concrete and Precast concrete walls with original families pack?  They are very common and used a lot.
Fri, Aug 26, 2011 at 6:44:23 PM | walls and columns
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
I assume that you're using revit architecture?
If you use architectural columns instead of structural columns, you'll find that the wall materials wrap the column instead of cutting through it.
Mon, Aug 29, 2011 at 5:54:47 PM | walls and columns
WerewolfV
Well, the scope of my project is relatively small and I am using structural columns vs. architectural.  Even with Architectural column I wouldn't necessarily want a wall to wrap around my column.  The column furring should be optional or even a separate element.  Example: your have nice concrete columns and you want to preserve their natural look.  There are some non-rated gyp. bd. partitions filling the space between some of them.  I don't want any of my drywall material to go around the column, but to butt against it.
intersecting walls and columns
Tue, May 4, 2010 at 5:08:07 PM
Strucutral Columns VS Walls in Call outs
Mon, Aug 16, 2010 at 8:17:06 AM
Structural Columns not cutting walls
Mon, Jan 4, 2016 at 4:13:26 PM
columns in walls
Mon, Sep 11, 2006 at 11:53:38 AM
Walls and Structural Beams/Columns and Finishes
Tue, Jul 19, 2016 at 3:46:12 PM
12
Page generation time: 2.0606
