45 Users Online (44 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> How to edit family parameres inside a group?
Thu, Aug 25, 2011 at 11:56:09 AM | How to edit family parameres inside a group?
franciscorefosco
I organize my drawing in groups.
Now I need to add a comment, or ever change a family parameters, but this family is inside a group.
When I try to do you, revit tells me "Error - cannot be ignored. Changes to groups are allowed only in group edit mode. Use the edit group command to change to all instances of a group type. You may use the ungroup option to proceed with this change by ungrouping the changed group instances."
I really dont want to ungroup, and since I have instances of this group, I would need to edit one by one or even ungroup everything.
thanks
F
Thu, Aug 25, 2011 at 12:21:16 PM | How to edit family parameres inside a group?
Ah.... groups.  You really have to understand them and be careful where and how you use them.  And learning that is almost all experience.
You wrote "...I organize my drawing in groups...."  Not sure what you mean by this but it sounds bad.  And as you have found out, when you have families that need different parameter settings, groups become a problem.
I don't have any really good advice - no easy solutions because this is really very specific to what you may be doing.  You may be able to break these groups up into smaller groups - then ungroup the larger group.  << Never tried this
edit group panel missing
Tue, Jan 17, 2012 at 2:54:43 AM
12
Edit group
Wed, Oct 29, 2014 at 7:41:46 AM
IN PLACE FAMILY PROBLEMS
Tue, May 12, 2009 at 5:29:50 PM
Getting plane based electrical family placed in family to show up in group
Fri, Apr 15, 2011 at 4:40:06 PM
Groups. Move partition walls, how?
Tue, Aug 12, 2008 at 2:16:59 PM
Page generation time: 0.9632
