36 Users Online (34 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Dog legged curtain wall mullions
Wed, Aug 24, 2011 at 8:11:54 PM | Dog legged curtain wall mullions
Pele
Pele Avatar
I saw this article but could not work out how to create the dog leg mullion
I will be scoring goals soon, I'm in the back line at the moment!
Cheers Dermot
www.dmbd.net
Thu, Aug 25, 2011 at 12:01:39 AM | Dog legged curtain wall mullions
Pele
Pele Avatar
I forgot I'm using Revit Architecture 2011
Cheers Dermot
www.dmbd.net
Thu, Aug 25, 2011 at 5:23:41 AM | Dog legged curtain wall mullions
4 Stars: 202 Votes
You need to edit the profile in that "GLASS PANEL" with the shape like in your image, then you can apply the mullions.
Thu, Aug 25, 2011 at 6:14:27 AM | Dog legged curtain wall mullions
Pele
Pele Avatar
I can change the shape of the panels easy but still do not understand how to make the irregular mullion. They appear to be a pretty rigid animal to me.
Cheers Dermot
www.dmbd.net
Thu, Aug 25, 2011 at 7:14:23 AM | Dog legged curtain wall mullions
You really can't do this with the normal CW mullion.  Instead, create an in-place family here.
Thu, Aug 25, 2011 at 12:29:10 PM | Dog legged curtain wall mullions
4 Stars: 202 Votes
Sorry, WW is right, you will need to create that with "In-Place" family.
Thu, Aug 25, 2011 at 1:57:42 PM | Dog legged curtain wall mullions
cadman6735
cadman6735 Avatar
5 Stars: 4 Votes
you can rotate the grid line for a mull, then select add and subtract segments to make the dog leg, but it does not look as pretty as the image you show
but grids can be rotated, for a better result I would agree with Hub
Edited on: Thu, Aug 25, 2011 at 2:00:04 PM
What I failed to notice is that it is a global rotate for all horizontal mulls...  but I have done something like this in the past (at least I think I have)  hmmm.  Either way Hub has the best solution.
Edited on: Thu, Aug 25, 2011 at 2:04:21 PM
I remember what I did, I broke the profile up into many CWs to achieve the look I was after.  and it still didn't look too smooth as I remember it, so just rendered it from a distance.
Edited on: Thu, Aug 25, 2011 at 2:07:14 PM
  • Ability is what you're capable of doing.
  • Motivation determines what you do.
  • Attitude determines how well you do it.
Quote by:  Holtz, Lou
  • Life is all about the attitude
Thu, Aug 25, 2011 at 6:57:11 PM | Dog legged curtain wall mullions
Pele
Pele Avatar
Thx folks, it seems too complex for me at the moment.
Cheers Dermot
www.dmbd.net
Fri, Aug 26, 2011 at 8:22:17 AM | Dog legged curtain wall mullions
cadman6735
cadman6735 Avatar
5 Stars: 4 Votes
Pele
It's not complex, if you know how to do a sweep you can do a dogleg mull, just use a mull profile for your sweep profile.
Use the face of your glaze as your work plane and adjust the offset of the mull as needed, if needed.
dog legged section
Tue, Oct 18, 2005 at 8:30:11 AM
Curtain wall with splayed mullions
Tue, May 10, 2016 at 2:05:32 PM
Curtain wall mullions
Fri, Jan 11, 2008 at 9:22:16 AM
Miter Curtain Wall Border Mullions
Wed, Apr 21, 2010 at 3:04:58 PM
Linked Level markers not like original file. dont dog leg.
Thu, May 11, 2017 at 1:20:34 PM
Page generation time: 2.6084
