113 Users Online (110 Members):
Forums >> Revit Building >> Technical Support >> Multiple dimension fields in schedule
2 Posts No Rating |
I am using Revit 2011 and am having a problem with the fields in a schedule. I am scheduling specialty equipment and noticed that the dimension fields for width/height/length, etc. appear twice in the "available fields" menu of the schedule. When I schedule the families, I have to add both width fields, etc to the schedule because all of the family information won't show up/schedule correctly in just one of the dimension fields. Obviously, I can't have a schedule that lists the dimensions of families sporadically across two separate dimension columns. What is happening here and how do I fix it?
Your families are built from two different shared parameter files. The shared parameter XXX in one file is not necessarily the same as XXX in a different file. The name is NOT what controls the parameter. Whoever built your families did not understand this and they created their own. If you have a standard file, you can always export a shared parameter to your shared parameter file so that it is the same.
2 Posts No Rating |
That's exactly what happened. Thank you.
Adding Window Parameters/Fields for Window Schedule |
Fri, Aug 15, 2008 at 1:23:57 PM
Schedule Problems : Deletes modeled items when I delete blank fields |
Tue, Sep 2, 2014 at 3:44:47 PM
Schedule Help : Adding multiple filter headings under one filter |
Thu, Aug 1, 2013 at 12:22:17 PM
Door Schedule Fields Clarification |
Mon, Dec 3, 2012 at 7:06:53 AM
Schedule fill in of multiple lines |
Fri, Apr 12, 2024 at 6:39:25 PM
13
Members: | 2022461 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
