38 Users Online (37 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> 24" Tile
Wed, Aug 24, 2011 at 10:21:06 AM | 24" Tile
renderforfun
4.5 Stars: 6 Votes
Ok I have done this a million times but I have a feeling im not doing it the right way. I am creating a 24" x 24" Porcelain tile and I would just like somebody to please explain the right way to attach the tile pattern. Bump maps still confuse me a little because some are colored and some aren't i dunno..........If this is in the wrong spot I apologize ahead of time. Thank You.
Wed, Aug 24, 2011 at 10:33:23 AM | 24" Tile
Do you have a material for this???
You could assign a 6x6 or 4x4 or whatever material you already have by increasing the assigned scale of the jmg & bump accordingly.  Then simply create a simple model hatch to match.
Wed, Aug 24, 2011 at 3:10:53 PM | 24" Tile
renderforfun
4.5 Stars: 6 Votes
That is how I usually do it but it seems that the grout joints scale up when you scale it, so then you have these beefy joints instead of a nice fine 1/8" or so...........Sometimes I take a picture of the actual tile and bring it into photoshop and create a pattern and make my grout lines and such that way too. I just feel this is really silly that a 12" or 24" tile isn't standard as a revit material or bump.
Wed, Aug 24, 2011 at 4:13:17 PM | 24" Tile
You are correct, my solution would not work.  You need a new jpg & bump file.
Wed, Aug 24, 2011 at 4:39:27 PM | 24" Tile
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
I'd take a picture of what you want, yes.  My most successful render materials have been created with a scanner or camera, and photoshop.  Getting the edges to line up is extremely easy if you *cut* the pattern mid tile, *paste* and *flip horizontal* on the opposite side of the image.  You'll see virtually no repetition in the pattern.
Here's out wood texture for cedar that we use heavilly.
We put a shingle on the scanner.  No kidding.  Looks better than every single wood texture included with revit, and is similar in size - 500kb.
Thu, Aug 25, 2011 at 8:17:40 AM | 24" Tile
renderforfun
4.5 Stars: 6 Votes
itsmyalterego....that wood texture is really really good. Also you are correct when creating your own material in photoshop or whatever it is, the quality seems to be alot higher.  I just can't believe this tile issue is not standard in revit, I guess you can't always get what you want.  Anyways back to the typical photoshop to create my tile. I will upload my rendering when its done to show how it came out. Thanks for the help guys
Staggered tile PAT file needed: 96" W x 21" H
Tue, May 20, 2014 at 3:19:03 PM
Tile Patterns, not line patterns
Fri, May 17, 2019 at 9:29:05 AM
Ceramic Tile Flooring
Wed, Jan 2, 2008 at 9:03:03 AM
Tile Pattern Height
Mon, Oct 9, 2006 at 2:36:03 PM
How are you all naming wall types
Thu, Nov 30, 2006 at 4:46:02 PM
Page generation time: 1.2482
