37 Users Online (35 Members):
Forums >> Revit Systems >> Technical Support >> Hide insulation in MEP 2012
2 Posts No Rating |
Hi
I have the new MEP 2012. When I assign my insulation to a pipe, it's impossible to hide it. Revit just hides the pipe, not the insulation. I know I can hide all insulation in visibility/graphic, but that's not what I need. I want to hide certain parts of the Insulation.
I hope there's a solution for my problem.
Grts
Brecht
I have the same problem in 2013 :/
2 Posts No Rating |
I did find a solution.
Select the pipe, click on "Edit Insulation". Then you can hide it width "Hide in View" or "Temporary Hide/Isolate".
I just found out it is a bug :/ but you can make the lines invisible.
Ohu thanks :D
pipe insulation and VG |
Fri, Sep 6, 2013 at 2:08:39 PM
Insulation |
Thu, Jan 9, 2014 at 12:43:43 PM
Plumbing insulation |
Thu, Feb 20, 2014 at 8:19:48 AM
TRIMMING PIPES - MEP 2012 |
Fri, Sep 21, 2012 at 9:06:37 AM
insulation line |
Fri, Dec 1, 2017 at 9:57:58 AM
Members: | 2056525 | Objects: | 23074 | Forum Posts: | 152325 | Job Listings: | 3 |
