94 Users Online (92 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> Boxing beams
Tue, Aug 23, 2011 at 6:43:55 AM | Boxing beams
archie456
3 Stars: 1 Votes
Hi,
I have a project which has loads of beams which requrie boxing in at high level.
Previously, I have just drawn a wall at either side of the beam (i.e. offset from the level to the beams height) and then drawn a ceiling below - though this process seems extremely time consuming and fiddly.
Is there a better way?
Tue, Aug 23, 2011 at 7:59:07 AM | Boxing beams
jterrell
3 Stars: 5 Votes
I made an 'architectural beam' family to accomplish this. Just us a column family and modify. Worked great for me.
Wed, Aug 24, 2011 at 6:10:17 AM | Boxing beams
archie456
3 Stars: 1 Votes
Sounds like that could be a plan - but how would you cater for the column casing being made of two layers of plasterboard?  Cryingas mine are)
I guess you could create an arch column which consists of two extruded boxes one inside the other??
trying to delete elements
Fri, Jun 12, 2009 at 6:42:24 AM
joining two beams
Fri, Jul 6, 2007 at 12:03:11 PM
making beams dotted and upstands
Tue, Jun 3, 2008 at 3:50:25 AM
Beams that are copied are invisible, while beams placed can be seen??
Sat, Jan 20, 2007 at 9:53:44 AM
RVT2015 - Insert steel beams over doorway
Tue, Apr 25, 2017 at 9:06:48 PM
Page generation time: 0.3713
