74 Users Online (70 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> Control of imported revit link question
Mon, Aug 22, 2011 at 4:58:10 PM | Control of imported revit link question
jcrocco
3 Stars: 1 Votes
I have a structural drawing linked in where I want to turn off their column lines, and use only the architecturals.  I can do it manually, but I have a lot of floor plans to do it in.  Can I globally somehow turn it off so no view has them on?
Mon, Aug 22, 2011 at 5:14:42 PM | Control of imported revit link question
This is where you need view templates. Create a template for each view type ....assign it to the views as appropriate.
Learn to use them because they are very valuable.
Mon, Aug 22, 2011 at 5:21:36 PM | Control of imported revit link question
jcrocco
3 Stars: 1 Votes
Actually, I do use them  I didnt know the views from revit links were also inluded, I thought only within the model.  Thanks.
Mon, Aug 22, 2011 at 10:53:43 PM | Control of imported revit link question
mirakation
Hi
you can customise it from revit links by going to visibility/graphics overrides,Revit Links then click on By Host View then select Custom then go to Model Categories where it is set to By Host view change it to custom and then trun off all the things you dont need.
Sorry i hope this help i dont know how else to explain it. Smile
Masking an imported link
Wed, Aug 24, 2011 at 5:59:57 PM
13
imported DWG visibility
Fri, Apr 13, 2007 at 12:26:23 AM
Issue with Link/Imported Structural Revit File
Thu, Jul 23, 2009 at 9:58:58 AM
Looking For Easy Way to Control Lineweights When Linking DWG Files
Fri, Jan 18, 2008 at 3:17:59 PM
column bubble question
Fri, Aug 26, 2011 at 3:31:26 PM
Page generation time: 2.0495
