52 Users Online (50 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> AutoCad Lines
Mon, Aug 22, 2011 at 11:35:31 AM | AutoCad Lines
nmccarty82
I have imported a football field from AutoCAD into Revit for a work project. I can see the lines in 3d mode but not when I render the image. What do I have to do to make the lines show up in the rendering? please help
Mon, Aug 22, 2011 at 12:13:50 PM | AutoCad Lines
3.5 Stars: 395 Votes
It will not show up in a rendered view.  That is because there are no faces to render.  You need 3D objects.  A site with something like parking striping will render.  You can split a topo face to create the field markings but it would be easier as one - in-place family - solid extrusion - 1/4" thick on your site...which is flat.
Mon, Aug 22, 2011 at 4:31:09 PM | AutoCad Lines
cadman6735
cadman6735 Avatar
5 Stars: 4 Votes
What about turning your cad file into an image and using it as a material map or decal or some other trick to work as an underlay for your rendering?
Images will render
Edited on: Mon, Aug 22, 2011 at 4:32:00 PM
  • Ability is what you're capable of doing.
  • Motivation determines what you do.
  • Attitude determines how well you do it.
Quote by:  Holtz, Lou
  • Life is all about the attitude
How to get pipe fittings to appear as simple pipe lines?
Thu, Mar 20, 2014 at 4:40:08 PM
12
Wiggly Lines when importing Topo into Revit
Tue, Jun 28, 2016 at 9:46:19 AM
AutoCAD and Revit
Mon, Apr 29, 2013 at 7:23:19 AM
Creating surface topography from Autocad file
Fri, Feb 25, 2011 at 4:15:11 AM
Importing AutoCAD topo 3D lines
Wed, May 25, 2005 at 3:33:44 AM
Page generation time: 1.0129
